Dynacord S900 Limit chB problem
  • Dynacord S900 Limit chB problem
    Hello
    After turning on the power - all red LEDs go out, but only Channel B Limit remains on
    Channel A plays without any problems, but channel B is limited and does not have much power.
    I noticed that when it works even without a load at the output - the radiator heats up
    Input shorted. Output no load.
    Output voltage in channel A, dc 0.66 mV to 0.90 mV / ac = 0 mV
    Output voltage in channel B, dc changes quite quickly between 0 mV to 1.3 mV / ac changes between 3 mV to 4.2 mV​
    After a lot of searching on the Internet - reading and watching videos, I repaired the amplifier. The problem was a defect in the operational amplifier (i302d) pin 13 I measured the voltage +10 volts / relative to the case / pin 14 also had +10 volts.
    After replacing this opamp - the protection is not activated and the problem is gone. It remains only to check the BIAS current. The output voltage is 0.8 millivolts DC​
      Nice fix!
      Thanks for the update.
