Hello folks,
Has anyone had any experience with this amp mod company?
I have a Fender Dual Showman that has a mod kit in it. Basically, it redesigned the entire amp. It runs on 6CA7 (EL34) tubes, and has a separate bias supply w/xformer to produce the higher bias voltage. Looks like it uses a regulator IC of some sort. I didn't look that closely.
The main issue with the amp as that the wires to the filter caps were apparently stressed & broke loose. The lack of filtering caused too high extended current thru the bridge diodes and shorted one of them.
The mod kit entails a new rivet board of high quality and a 3.5x3.5" board with a relay on it that appears to be for channel switching. About the only 'Kloogy' thing I was that this small board was wrapped in electrical tape and just kinda stuffed in the chassis. I subsequently zip-tied an insulator sheet to the bottom of the board in place of the electrical tape & affixed it to the chassis w/zip-ties.
The entire mod in general appears to be fairly well thought out & functions fairly well, except for some oscillation on extremely high levels. I tried to move lead dress to eliminate it with no luck. Since it is only at extremely high levels, I just left that way.
The master volume pot is the dual pot type that merely shunts the PI drive signal to the output tubes. It does attach between 4 coupling caps that serve to isolate the pot from PI plate voltage and Minus Bias voltage on the output tubes.
I did have an issue with the Mstr Vol clipping the positive sinewave to the power tubes that appeared to be resolved by putting the wiper of the pots on the PI side as opposed to the output tube side. Don't even ask how or why. Amps with mods have lots of weird artifacts that I either can't or won't try to explain even to myself!
Anyway,
Just wondering if anyone has seen these mods on this or other amps and what you think of them.
Thanx, Glen.
Anyway,
Thanx, Glen.
