Most compact momentary foot switch
  • Most compact momentary foot switch
    I'm looking for a really compact momentary foot switch that either needs to be a soft-touch or membrane type. As a last resort I'll make my own, but really wanted something off the shelf. All the usual ones I've found are too big and I have a real challenge to cram a lot of stuff into Hammond 1590B sized box - microproceesor board, + support electronics, three switches, foot switch, 4x pots, 4x 1/4" sockets, DC socket, bezel-mount LED and opamp etc. It's easy to build this into a larger box, but I challenged myself to get everything as compact as possible.
    I've spent a long time looking, but everything is filtered and skewed towards the same stuff, so maybe someone has seen something that may work out.
    Are you looking for something with smaller than usual size of actuator?
      I mean, you could use a tac switch and 3D print a foot button...
      http://amps.monkeymatic.com
        The actuator needs to be a regular size. I can machine up a button assembly in stainless to hold a tactile switch, but the intention is to create a piece of equipment someone else could build without too much difficulty. With this in mind, something off the shelf would be better. I don't have a 3D printer, but have machining facilities.
        ​I've got some Alpha momentary switches but these have an overly strong click action. The body size is acceptable though and it may be fairly straightforward to replace the innards with a tactile switch. It needs to be sensitive enough for easy double-clicking with the foot.
          You've probably already seen all these, but if not they may give you some ideas.
          https://www.banzaimusic.com/Pushbutt...hes-Momentary/
            Thanks, I'd overlooked the description of one of the switches: In the link there's a low force version of the Alpha switches I have and this looks to be just what I need.
              Just curious: in my book the words "Tact/membrane" switch and *foot* activation don´t go in the same phrase.
