Greetings,
I have an old PA amp that uses 6SJ7 preamp tubes that I’m tweaking for guitar use. It has three essentially identical channels. The plate, screen and cathode resistor values and voltages are shown below. The screen voltages are quite low and I would like to bring those up to about 80-90V range (based on other forum posts I have seen). Is it just a matter of reducing the screen resistors until hitting the desired voltage? Or is there something more that needs to be done? I’m a hobby builder but not much of a tech or designer. Thanks.
