I'm working on a Fender Twin Reverb, it has the numbers A775176 on the inside. The schematic I'm using is on page 456 of the Groove tubes 4th edition tube amp book.
This unit exhibits a slight fuzz sound when notes are played at low volumes.
I have taken voltage measurements on all the tubes and find nothing abnormal.
I have substituted new tubes (both preampt and output) and the problem still exists.
I have substituted the 3 20uf/500v caps and the problem still exists.
I have not been able to substitute the two 220uf/285v caps, I do not have anything of that size in my stock. Could they be going soft?
Measuring the resistance of the output transformer with RED being the center tap, the results are (I am using a Fluke 87 multimeter) :
Between RED and BLUE 39.6 ohms
RED and BLUE/YELLOW 4.7 ohms
RED and BROWN/YELLOW 5.3 ohms
RED and BROWN 37.4 ohms
Is the output transformer bad?
Any thoughts or suggestions?
Thanks,
Dan
Thanks,
Dan
