switching riddle
  • switching riddle
    Hey I'm goiin to build these into pedals but I want to build both in one box with a switch to toggle between them. I having a hard time figuring out how to do it tho. I've tried to draw it up with a dpdt but I think I'd need a 3pdt. Could someone help me figure this out?
    The schem is at www.runoffgroove.com/grace.html
    I assume they will both run on the same power supply. All you need is to switch them in and out of the signal line. You might hear a pop when you switch between them.
    Hope this helps
    Matt
      tx, i was wondering if you could avoid the pop with a resistor (across the switch) of huge value like 10 meg- you could adjust it for leakage from the other channel i'd think...
        Yep, that's right. Didn't want to make the drawing more confusing. I think best way would be to add a resistor (I used to use 2meg) from input to each effects input line (on the switch) and same on the output. That should avoid pop.
