Hi
Having a few problems with this Korg SDD-3000 delay.
Replaced the backup battery (the old one had leaked) and most of the
electrolytics in the power supply for modern 105 deg types ..On the front panel every thing seems to work fine ie remembers program/patch settings
after power off and on again.. delays work ok can get chorus/flanging type
sounds on very short settings etc BUT when I drive the input into the red on the front panel headroom VU the digit display reverts to the default setting
(program 1).
My initial impression is the audio section is draining power from the digital
section on peaks. If the input is set to a lower level (-5dB ,-10dB) so that it doesn't max out everything seems to work OK.
Anyone any clues ?
In the meantime going to try to trace the supplies to both sections.
(program 1).
Anyone any clues ?
