Attempting to fix a mixer VU meter
  • Attempting to fix a mixer VU meter
    I have a Samick 16 channel mixer where the left channel VU bar graph stays full on. Ive searched for a schematic with no luck and have checked most of the componants on the left channel PC to find nothing out of whack.
    If anyone has a schematic or could point me to one would be very appreciated.
    In general, the reasons for this could be:
    1- Open ground in meter circuit
    2- Audio oscillation
    3- Bad display drive IC (very often either LM3914 or LM3915)
    I do NOT have a schematic, but as an experienced tech, these are three possibilities.
    John R. Frondelli
    "Mediocre is the new 'Good' "
      It uses a Sharp brand 22 pin IC for the display, I dont have the number handy.
      This meter can view the left channel output along with the sum level via a pushbutton. When the button is enabling the sum view it causes an increase in the left channel output level.
      It uses a 20k trim pot bridging the Vmin and Vmax together. I checked it and it seemed open. I remove it and check it and it would show no value on a meter. I check it again later and its showing proper value.
      During various checks I found if you run a source through a channel and the left fader with both in the full fader the display will operate backwards meaning as a sound level peaks the meter will drop out LED's from top to bottom.
        IR2406G is the Sharp chip. It has three OP amps in use, two 1022B and one 1007B.
        casinolevant levant casino
