Hi All,
I am a newbie to the forum so I hope I found the right Forum
. The issue I have is I am getting a buzz from my monitor speakers. I believe it is ground loop related. I have a Peavey amp for monitors and two crown amps for the mains. I have separate outlets for both. I disconnected all the inputs from the amps but I still get a AC hum from the monitor speakers. The amps are switched on via a hospital grade switches in the sound room. All of the amps are rack mounted. I did noticed that when I leave the main amps off the monitors are a lot quieter. I have ground lifts on all of the plugs. If I don't use them the hum is 100% louder. The mains drive a Bose Sub woofer and arrays. I also noticed that as I was bolting the monitor amp into the rack I could hear noise as I turned the mounting screw.
