Hello all!
Great Forum!! I've just completed a build for Jack Orman's Q&D Compressor 2, based on the Analog Devices SSM2166 IC. I love it! It will take unbalanced line level, instrument level, and high impedance mic level without any modifications. The compression is musical (not invisible), and the limiter and gate are surprisingly nice as well.
Feeling lucky, I decided to add a 10-segment LED VU-scale meter to the circuit, based on the LM3915 IC. I thought I'd like to be able to switch the meter between input and output with a SPDT on-on switch, so I wired the switch to feed my little metering circuit from either the input or output jack. Since I am using a 12V 200mA wall wart for a PSU, and the Q&D only draws about 15 mA, I'm using the same supply in parallel to power the meter circuit.
The problems I'm having are:
1) When I switch the SPDT, I get a loud pop.
2) The meter starts off showing 8 LED's lit when there's no signal, and when there is, LED's 9 and 10 seem to light when the signal is strong. It's as if the meter is seeing an oscillator output set high enough to light the first 8 LED's, and then when I play music through it that's loud enough to surpass the level of the oscillator, the meter functions properly.
3) I can't meter gain reduction!
Is there some other place on the compressor circuit that I should be getting the meter feed signals from? Should I use a different IC? Is using the same PSU for both circuits illegal? If I want to run more compressor circuits from the same PSU, can I simply wire them in parralel?
For now, I've disconnected the meter portion, and am loving the compressor! The SSM2166P (DIP package) has been discontinued for several years. AD is now making the part in a surface mount SOIC package, which I was able to use thanks to a little SOIC-DIP adapter I got from Digikey, and it's working fine.
If I can work out this metering issue, I'm going to build 22 more - one for every input channel on my mixing console, one which I plan to mount inside my semi-hollowbody electric guitar, and one more inside my upright bass! I think a 5-segment LED array might be more appropriate, seeing as this whole build lives on two mini PCB's I got at Radio Shack (1.5" x 1.5" for the compressor, and 1.5" x 2" for the pot/meter card), and could easily fit in an empty cigarette pack!
Thanks in advance - for 30$ in components, this is an easy and worthwhile preamp, gate, compressor, and limiter! If anyone's interested I'll post pictures, BOM, PCBlayout, etc.
-James
-James
