Tube Mic Preamp Schematic
  • Tube Mic Preamp Schematic
    Does anyone have or know where I can get a schematic for a complete vacuum tube preamp for a microphone? Essentially I want to build a channel strip for my brother to use with his home recording studio. Anything classic or something you've built or tried would be great. Thanks.
    Dave
    Try entering this in google:
    rca mic pre schematic
    The top hit is one-electrons site with a ton of schematics, not all RCA by the way
    ANd www.waltzingbear.com also has a number of nice tube circuits for mic pres.
      Paia have a schematic and a kit here:
      http://www.paia.com/PAIA/tubestuf.htm
      and there are upgrade suggestions here:
      http://www.tapeop.com/magazine/bonus...micpremods.pdf
      Looks a nice project.
      S.
        Thankyou both. I'll look over those areas. Does anyone have any recommendations for one particular model? I just want to pick a good one.
        Dave
          Well, I love where you're heading. You might want to shortcut to these two items:
          A telefunken tube mic clone (there's a tube preamp right there built in)
          http://www.apexelectronics.com/pdfs/smapex460.pdf
          Upgrade above with a upgrade capsule $100 and output transformer $50. But regarding the transformer I'm considering just having a bypass option by adding a female 1/4 out to plug into a line in. Why not?
          Anybody?
          With these extra matching transformers it seems akin to multiple A/D D/A conversions in series. It's not balanced but unless it's live you've got a low Z singal you're only traveling a short distance.
          paired with a 12ay7 two tube preamp by EH
          http://www.musiciansfriend.com/produ...7&src=3SOSWXXA
          You WILL have amazing tones assuming the best downstream.
          I'd yet to see a schematic for the EH though I took mine apart and seen it was very well made.
          I have a Fear#n preamp schem if anybodys interested here that I made up while having one for a short while. Alot like a JCM 800 but way low gain. Amazing unit reminding me Sondano build quality.
          Edit: having trouble uploading the pics. Says it's not a valid image file, which it is. Dang!
            It's only valid if it is one of the types this board allows. Can we post images here? I thought we had to link to files elsewhere.
              I found a variant of the Altec 1566A via ePanorama
              http://www.epanorama.net/links/audiocircuits.html#tube
              Here's the Altec link:
              http://www.tangible-technology.com/tubes/1566/1566.html
              Enjoy,
              S.
                Yes, you can post images using the "Manage Attachments" button below the box where you type your post.
                Regarding the transformer thing, some people would say that a lot of the sound of tube mics and vintage preamps is really the harmonic distortion and frequency response anomalies caused by the audio transformers in them. I heard that the old Telefunken tube mic pres had some strange and wonderful iron in them, including a complicated choke that got degraded every time you plugged a mic in with the phantom power on. I don't know whether you need to spend big bucks on the likes of Jensen or Lundahl transformers to get the "Mojo".
                PS. Gyraf make a nice tube mic pre kit and the schematic used to be kicking around online http://www.gyraf.dk/
                  Steve and Sock,
                  Thanks for the links. This gives me a lot to work with. I appreciate the help!
                  Dave
                    You are right Steve the Input transformer is everything in tube mic pres.
                    http://www.jensen-transformers.com
                    KB
                    holiganbet betturkey
