Microphonic wireless?
  • Microphonic wireless?
    Wondering if anyone has run into this one before....
    I bought a used AKG Dual Pro wireless for guitar... it's actually 2 separate units in one box with one power supply.
    One side works great, the other side squeals through the guitar amp. (The first time it happened, I actually thought it was the monitors feeding back and started grabbing the rack EQ!
    Last night, I took the cover off of the base unit, and I could get it to ring by tapping on the metal chassis with my wedding ring. I didn't have much time to work on it last night, but tonight I intend to pull the circuit board, check for faulty solder connections, and try using rubber grommets as shock mounts for the circuit board.
    Any ideas on this?
    Thanks!
    Neal
    You shouldn;t need rubber grommets - find out what is microphonic and fix that.
    casibom< giriş/a> betturkey
