Hi,
Stupid me! I made a bone head mistake when I plugged my 110VAC wall wart adapter into 220V (I live in Thailand and have both 110 and 220 stuff). I have a very good 220 to 110 converter. But I didn't use it.
Would you believe it! he adapter is fried! Duh!
Here's the problem:
The burned out adapter (I'll call it #1) says 110VAC to 12VAC 1.5 A. with no mention of wattage.
The one I want to use as a replacement #2, says 110VAC to 12VAC 25 watts, with no mention of Amps.
Also when I put #2 on my multimeter it tests out around 14VAC instead of 12VAC.
So, as an amateur, I'm looking at 2 problems. While #1 says 12VAC 1.5 Amps, #2 says 12VAC 25 watts. I don't know enough electronic theory to determine if this is OK. Then. the second problem is the difference between the 12VAC specified and 14VAC actual readout.
My opinion is that the unit (an Axon AX 50 USB Guitar to Midi converter) will draw what it needs in terms of Amperage or Watts, and the necessary thing is to get the voltage right. But the reading of 14VAC on my multimeter bothers me a little. I've seen higher than specified voltages come out of many DC adapters, but was wondering, is this within an acceptable range for an AC/AC adapter?
Thinking it would be OK, I plugged a lower powered 110VAC/9VAC adaptor in for a second, and didn't get much response. When I plugged in the one I'd like to use into the proper voltage, then into the Axon it looked like everything was back to normal. It went through the normal startup routine, telling me the firmware version #, and proceeding to patch 001. However, though this made me happy that the adapter, and not the AX 50 was damaged, I shut it off, because I wanted a more expert opinion before I start actually using it normally.
Can I use the replacement without fear of burning out the Guitar to MIDI converter box it is powering?
Thanks,
Buzzer
Here's the problem:
Thanks,
Buzzer
