Capacitor help (sawtooth signal)
  • Capacitor help (sawtooth signal)
    Hi guys, I am using a PIC Micro to generate a signal of 11hz per second (i.e. it pulses 0 and 1 eleven times per second), which will generate a squarewave signal.
    I want to modify the signal to output a 'sawtooth' signal. How do I calculate the capacitor value to use?
    Is there a formula to use where I input Voltage, frequency etc.
    Thanks
    If you want to convert a square wave to a sawtooth, you need more than just a capacitor, you need an integrator with a reset switch.
    Go and look at the schematics for a Roland JX-3P or whatever, these have square wave oscillators that are converted to sawtooth by an analog circuit.
    If a somewhat misshapen sawtooth is acceptable, you can use a RC network with a diode across the resistor to sharpen the falling edge of what would otherwise be a misshapen triangle wave, and adjust the duty cycle of your PIC output to suit. The time constant R*C should be about 5-10 times longer than the period of your wave.
