Mixer-Amp Output Help!!
  • Mixer-Amp Output Help!!
    Have a Peavey messenger m100 portable powered mixer pa system
    Everthing works input cd, mics, headphones, line out BUT......
    Both Main L and R speaker ouputs do NOT work.....
    Bad power amp??
    Speaker output relays??
    Fuses??
    How could I fix or Test....?
    Please Help....!
    The Messenger has a digital amplifier. it runs off the same +/-25VDC that the +/-15VDCs are derived from for the preamp stages. There are no separate fuse, nor are there speaker relays.
    Are the speakers TOTALLY silent? Or is ther any background sound in them?
    The power amp board has three connectors - in, out, and power. You should have +25, -25, and grond to CN100, CN102 has the wires to the speaker jacks, make sure they are still connected, and the inout signakl from teh mixer is on CN103.
    casibom< giriş/a> betturkey
