I have pulled out power pcb and noticed a lot of discoloration under the rectifier. Also the sloder has pushed out flux on the power tube sockets I know I know yes the tubes were hot plated....But what would common symtoms of rectifer failure?? or capacitor failure?? The rec. pins have a blueish tint to them also... My hopes are to get a rectifer replace it and the caps also if i can find them put her back together n jam well is dosent hurt to hope...right???Also does any one have a good link for caps I found a couple but none had the same size and well the jtm has heat issues and the ones i found are shorter and fatter moving them closer to other componets.
Thanks in advance for any advice..101
