Fender Deluxe 85 - Channel Switching
  • Fender Deluxe 85 - Channel Switching
    Evening all,
    Recently obtained this amp (lovely sound!) but note that when I use the foot switch to change channel, it flicks from channel 1 to channel 2, then for a split second back to channel 1 before finishing as it should of channel 2... !!
    Also note then when switching to the boost channel, if I play a bassy note, it seems to flicker between the 2 channels for a split second again.
    Any advice?
    Thanks
    Andrew
    Electriclly loose switch in the stomp pedal comes immediately to mind.
    casibom< giriş/a> betturkey
