Hi all,
I'm writing to ask for your opinions on room mode compensation.
The acoustics in my living room have always sucked. I got the upper frequencies under control with some rugs and wall hangings, but the bass is still dreadful.
Lately I did some research, and discovered that the room has two plastered brick walls on opposite sides. Brick is very solid, so it doesn't absorb bass, and rugs and drapes don't either. The speakers are against one brick wall, and the couch is against the other, so the conditions are just right for a big standing wave. I can't really move them, because the couch is too big to fit against the non-brick wall.
So, I experimented with a parametric EQ, and found that if I cut 8dB at 60Hz with a Q of 3, the problem was solved! Bass never sounded better. Also, the 60Hz figure agrees with theoretical calculations from the distance between the two brick walls. There will be other modes, but just notching this one made a huge difference.
So the question is, what to do about it? Why should I bother building bass traps, and having them take up room space, if I can just EQ it? And, what should I EQ it with? I don't really want my parametric EQ tied up. I could build a box with a stereo 60Hz notch filter inside. Or for about $150 more than the cost of parts for that, I could get a Behringer DCX2496, and have lots of other cool features besides EQ. None of which I need.
