I'm nearing completion of a reproduction outboard power supply/spring reverb for a Farfisa Compact Duo organ, the unit known as the F/AR. (I bought an organ that was missing its power supply.)
The outboard unit supplies 9VAC (~300mA) through a Leslie cable-style umbilical that also carries the audio signal from the organ. Farfisa ran this 9VAC to the organ via a coaxial cable inside the umbilical. One side of the 9VAC secondary is referenced to ground inside the power supply, and this side is connected to the coaxial cable shield. Thus, the shield does carry AC current, being the ground-return path.
What I'm wondering is whether, theoretically, it would be better to send 60Hz AC through an umbilical like this via a twisted pair or a coaxial cable. 'Better' would be defined as having less tendency to couple 60Hz noise into the audio signal.
I suppose the best method would be a twisted pair with a non-current carrying shield around the pair, but I'm not sure that's practical in terms of the thickness of the umbilical.
I'm more interested in seeing how various forum readers would approach the problem :-)
