I was prepping my PA system this evening and lost about half the gain on the left main of the board. While I am not certain, I believe it dropped about the moment, I was trying to roll in a little more Aux2 (reverb unit) at the Aux 3 master.
First appeared as the Bottom two speakers on one side sounded weak could practically only hear the horn. We isolated speakers to rule them out, bypassed FX unit, EQ unit and swapped things around to rule out the Main Crown amp, it was ok. It came back to the Left Main output of the board simply lost about half it's gain.
We rechecked the pan pots, assign switches, etc all ok. In ever other aspect this board is working properly. We compensated with about double the fader on the left ch (still below unity) and the channel sounds simply wonderful.
Any advice on further isoloate this? I have read ENZO's other post on isolation but I assuming there is a preamp section that pre amps that left channel as it leaves the board (not sure). This board uses an external power supply, would the op amps etc be in that ext. power supply?
Any ideas or should I just run it as it is?
Thanks,
ENB
Thanks,
ENB
