I meant to do this to a 100K volume pedal that I took apart just now, and then got to thinking, "Hmmm, this wont work." So I called Fender, who sells such pots, and they have no record of such a resistance-breaking pot being used in a volume application.
Wired with two lugs; Hot and Ground.
Hot will open at max setting and look like a wire connecting In and Out.
This will work, no? But how well, and what of the taper? I suspect most of the change would happen close to ground. So perhaps wire an audio pot in reverse? I have heard the terms voltage divider and variable resistor.
The best dialogue I found on this was here: No load volume? - Telecaster Guitar Forum
If this wont work I must add a buffer, such as the always buffered Boss pedal (a J201 made a huge tone difference for Q1) , before that passive volume pedal. I just wanted to keep my first pedal line all true bypass; got A/D convertors ahead! Maybe I just should've called Pete Cornish
I do like my tube buffers.
