WET\DRY effects loop pedal?
  • WET\DRY effects loop pedal?
    ok, i have been in the process of building my own true bypass looper strip for awhile. and for my phaser and other modulation effects i am thinking about using a wet\dry blend pot.
    HOW CAN I DO THIS?
    can i simply put a pot somewhere in the loop of the send\return to blend the loop with the dry signal?
    I wonder if the concept of a true-bypass DPDT switch can be moved towards a dual-gang pot. THis would work the blend you and others are looking for.
    marsbahis betturkey
