korg triton pro
  • korg triton pro
    I am having a problem with the touch sensitivity on my Korg Triton Pro and I am unable to find anything in the manual that adresses the problem! Anyone with any advice?
    Now do you mean the velocity? As in how hard you hit the key affecting how loud the note plays? Or do you mean aftertouch, which refers to pressing down harder on the key once it is all the way down? AFtertouch can be assigned to a variety of functions on each patch - and it can be turned off.
    Aftertouch uses a narrow membrane ribbon running the length of the keybed, then wired up to a small board about the size of a business card, and mounted on the keybed frame. If it is aftertouch and it is just not working, you can measure the4 sensor strip resistance with an ohm meter as you press down hard on keys
