Repair a 10 pin plug
  • Repair a 10 pin plug
    Hi,
    I've a 10pin plug but 2 are missing, and one of them is fore the Audio out
    I'd like to know if it would be possible to repair it because there are now discontinued so I can't buy a new plug.
    Here is a pic, 1 and 9 missing :
    Thanks !
    Maybe use the pins from an octal tube base?
      You may be able to locate some brass rod of the same diameter and craft your own pins. Then tin plate them? maybe?
      Now Trending: China has found a way to turn stupidity into money!
        I have seen small diameter brass and copper tubing at large, even small, hardware stores.
        holiganbet betturkey
