I have a Standel Studio 60 with 6 4ohm speakers. They were not wired when I got the amp.
How do I wiring up 6 4ohm speakers to a 4 ohm amp
I can't see any way that gives the exact impedance. You could have two parallel strings of three series speakers for 6 ohms, or three strings of two speakers for 8/3 of an ohm, but not 4.
If it's a transistor amp I'd go for 6."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
so all + and - together
4+4+4= 12
4+4+4= 12
12string+12string=6
am I thinking right ?
By the way I went to Scottland in 1982 with my church group for 2 weeks.
I love your country, wish I could go back. Driving a 16 person van with my group was very intresting to say the least
Not quite...
Each speaker has two terminals that should be labelled + and -. Take three speakers and connect the + of one to the - of the next.
Code:(- +)---(- +)---(- +)
Code:(- +)---(- +)---(- +) (- +)---(- +)---(- +)
and then connect the -'s and +'s you have left to the amp.
Code:|-(- +)---(- +)---(- +)-| | | |-(- +)---(- +)---(- +)-| | | v v to amp
1982, wow, I was 4. Where in Scotland did you go?"Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
Standel / Sorry off subject a little.
We spend a week in Glenrothes on a bible school with 43 people. Then we had a week to travel. We broke off from the main group and 7 of us "an a driver,guide" when to St. Andrews, Edinburgh,Loch Ness. All those cool places. I ran across some Rogers folks too. Heard alot of tales, and met some of the most wonderfull people in my life.
thanks
Jess Rogers
jessadr@comcast.net
P.S. I have a 80watt 2 channel I am going to use with the Standel. The factory amp has problems. The preamp and effects work great, so I can run 3 speakers per side. I am going to mount it in the bottom of the cab. It is about 5 feet tall , got penty of room.
Depends how you define closer. For an old solid-state amp, you want to err on the side of a higher impedance. Overloading some early transistor amp is like asking your grandma to help you shift that piano.
If it were a tube amp then the 2.7 ohm option might be safer."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
