Behringer Parts Surplus Blowout..."Pots By The Pound"!!!
  • Behringer Parts Surplus Blowout..."Pots By The Pound"!!!
    It's official. We are over-run with surplus Behringer parts, mostly pots of the following types (referencing Behringer products):
    -Type "B" Pots: Round, brass case w/long D-shaft for older China production Non-Pro processors, and some new ones. Alpha and Alps.
    -Type "C" Pots: Small, square, plastic-body w/plastic D-shaft (center-detent), Mixers ONLY. Panasonic mixed with some other brands.
    -Type "D" Pots: Small, square, plastic-body w/plastic D-shaft (21-detent), Pro-series processors ONLY. Panasonic mixed with some other brands.
    Of course, most of these pots can retrofit units by other manufacturers. Even the long D-shaft types can be cut to fit. We do. Everything is mostly PC-mount.
    Rather than doing a stock overage inventory, I want to blow-out these pots by the pound, like the old-style parts grab-bags. This is all guaranteed useful, quality, first-run, unused stuff. I am going to keep the prices reasonable because really, we need the room for other stuff, and we have PLENTY for our own stock. Anyone interested in this should PM me.
    John R. Frondelli
    "Mediocre is the new 'Good' "
    I gotta ask...approx how many pots per pound?
      The metal pots are about 24/lb., while the plastic pots are app. 144/lb. I say approximately because we are going to use a scale to weigh them. We want to avoid counting. Hence, I am going to break it down into two categories: plastic and metal. $36/lb. plastic and $12/lb. metal.
      I will tell you that we have wide variety of pots with different tapers, detented and center-detent, tapped, dual, single. Personally, I cannot even believe how much we have, and since I have been lugging it and staging it for sale, I am all too well aware of this! :O
      This is really just the tip of the iceberg. We will also have transformers, knobs, mixer rack ears, switches, faders.....
      John R. Frondelli
        Please keep me informed of the deals! knobs and faders i need all the damn time. those faders with the LED lights in them break if you breath on em!
        Also interested in dead amp modules and switcher power supplies.
          Contact Steve Daniels over at Small Bear in Brooklyn, if you have not already done so. He sells parts to pedal builders, as well as pedal-makers. He may be interested in a bulk buy.
            Thanks Mark. I really have to get rid of some of this stuff. We're buried! :O
            John R. Frondelli
            casinolevant levant casino
