Boss DD3 passing dry signal only. Help
  • Boss DD3 passing dry signal only. Help
    I have an older Boss DD-3 from late 80's/early 90's that is passing dry signal only. LED is working (on/off) but no delay effect. Any Ideas what could have caused this or what to look for to fix this. It has board mounted components. Thanks for any advice..
    Steve
    a bit obvious but you aren't plugged into the direct out are you?
    alternively you could try the bossarea forum, laurie is the man when it comes to DD3's.
      Some excellent info here
      http://music-electronics-forum.com/t14908/
