That feeling you get when you're two hours into a repair, still miles away from having an accurate estimate, and you're beginning to think the equipment has been struck by lightning...Yay.
Working on a Yamaha EMX660 mixer/amp. Started off as a simple +15v reg replacement. Got the 15 volts going, smelled something heating up and found an IC on the front panel getting exceptionally hot. Cool, I thought, there's the original culprit that took out the regulator. Didn't have a replacement, so I pulled it from the circuit (it's a graphic EQ IC). Fired it up, something still pulling down on the +15 volts. Found another cooked IC far away electrically and physically from the first. Replaced it. While troubleshooting that, I suddenly started getting wacky readings everywhere. Couldn't find a ground reference anymore on the front panel, in fact the ground for the +-15 regs didn't make it off the power amp pcb. Great... pull the power amp board and fix the vaporized ground trace. Fire up, something still tugging on the +15v line. Pulled the ribbon to one of the front panel boards to isolate the problem. Heard a small "pop" and suddenly all the voltages looked ok. Of course both LED meters are still completely lit up, so I have at least one or two more problems to find.
Aye Carumba!!
PS: Just needed to vent. I feel better now!
Aye Carumba!!
