I was given a non-working Crown Macro-Tech 2400 that I fixed last night: a transistor lead had broken loose from its solder pad, probably from rough handling. Other than needing a new On/Off button, replacement of a bent binding post, and, I suppose, I new air filter, it seems to be in good working order.
Based on date codes on transistors and capacitors, it looks like it's from 1988. I wasn't aware that the Macro-Tech series went back that far, and the documentation Crown has on their site doesn't give much information on version history this old. (It looks like all their documentation has been re-worked to reflect the Harman International ownership.)
When did they start making these?
David
David
