howdy folks,
i'm curious if anyone out there has come across or has any experience with this schematic. i've been attempting to build a little mock version of this which doesn't seem all that hard, but this schematic is a little vague on how to wire up the heater elements to the 12AX7 and the EL84. i'm also wondering the purpose of the the connection between the 6.3v AC tap and the 3 pin on the EL84. should that not run to ground along with the 100uf bypass cap? experience tells me that it's definitely not advisable at it is drawn here.
anyhow, thanks for the help.
