Hello guys,
I'm new to this forum. I found it by chance on google while i was trying to find a solution to my problem, which is a piezo problem that i couldn't find an answer on this site too. So i decided to post a new thread.
Well, i have an alhambra 1p classical guitar. 2 years earlier i decided to amplify it and gave it to a so called "luthier" who actually didn't do it as he was supposed to do. And since he is far to where i live i decided to repair it on my own.
The problem is a balance problem i guess. The best sounding string is the b string.
So, if;
B string sounds 100%,
High E string sounds 90%,
G string sounds 10%,
D string sounds 30%,
A String sounds 40%,
Low E string sounds 35%.
By the way, the saddle is straight. I checked it. There is no curving. So i am sure it fully presses on the piezo cable.
So what i suspect is the piezo. I thought if i could change it, everything would work fine. But i am no luthier. So, i need some advices.
Here is the preamp that i have
Uploaded with ImageShack.us
Back of the preamp
The circuit board on the back, the little green thing with the two screws contains the wires that comes out of the piezo coax cable.
I took a close look to the piezo and found out that it's been torn apart here and there. Here is the photo of it.
And the photo of inside of the guitar through the hole of preamp
And a closer one where you can see the piezo's starting point where it cuts through the top of the guitar and lays down the saddle.
Do you know what might be the problem, any ideas? I suspect the piezo cable due to its condition, it shows some wear here and there.
I also have another idea of changing the piezo with Artec's ceramic piezo element. Here you can see it
So the problem about this is it has a different end than my cable. One has a jack end, the other has two cable ends soldered on the circuit board.
So can i just buy the ceramic piezo, cut the jack end, split the wires and solder them on the circuit board? Would it work? Any ideas?
Thanks for everyone who participates.
So, if;
Back of the preamp
