I searched the forum to make sure I wasn't duplicating something here.
I wanted to FYI anyone interested.
I started work on a Mackie M1200 amp. It is in protect constantly on one channel.
I pulled the main board out and found that the unit arced over from the -80V diode (D8) to the heatsink. it was very obvious. looking close the PCB with all the output transistors and all is very, very close to the heatsink and has little insulation to prevent such and issue. I cleaned the pcb and ground out the pcb that had carbonized.
I then took strips of kapton and made some 90 deg long strips to place between the PCB and heatsink.
The issue with protect looks like a leaky transistor (Q79) placing the unit in SOA fault.
I pulled R159 and the unit still went into fault. pulling R161 stopped the fault and the amp worked well and bias was correct.
Mackie-M1200 1400
Mackie-M1200 1400
