73 Twin Speaker Choice
  • 73 Twin Speaker Choice
    I'm replacing my 73 Twin's speakers. I blackfaced it a while back with the great assistance I found here. I'm going with Eminence. I've considered the Red White and Blues and also the Legend 1258's. My question is the 1258's are only rated at 75W would that be ok for a 100w amp? I'll never really crank this amp up too high. Would also appreciate any opinions on which Eminence you guys like for a Twin. I play blues, funk etc and wouldn't mind some grit / breakup the old speakers where original JBL's, too clean.
    Thanks in advance.
    Those would be fine because you are using two speakers and each can dissipate 75Watts of power. Consider the Marshall 4-12 cabinet. They are designed for 100W heads and typically use 4 - 25Watt speakers.
      Thanks again Gibsonman63
