I looked through the forum to make sure I wasn't replicating an old post and I didn't find any solid answers there.
I have A QSC 1400 that the soldering on the bottom of the board was very thin and many of the output transistors and main caps arched and burned the traces around the cracked out solder. Many of the transistors have failed. anyway that all can be repaired but I'm left with this question.
This unit looks like its straight from the factory, meaning It doesn't look like its been repaired anywhere else before but...
The output transistors are MJ21194 and MJ15025s installed these are not really complementary?
Shouldn't it be MJ21193 and 94 sets or MJ15024 and 25 sets?
The schematic shows 2SB554 and 2SD424s
Thanks in advance
BTW this amp looks almost brand new. very clean internally and externally
Thanks in advance
