Hi,
I'm repairing an old Peavey CS1000x. It's got a lot of shorted output transistors. The two drivers have Peavey numbers: 70481180 and 70471180. They look like they've survived. The output transistors are MJ21193 matched with a mix of MJ15024 and 70483180 (seemed a strange mix to me).
So four questions:
1. Does anybody have a table of equivalent transistors for Peavey transistor numbers.
2. Does anybody know what transistor numbers the MJ21193 have replaced.
3. What transistors should I be using for the output transistors on this amp?
4. Is there anything else worth checking/ servicing while I'm in the amp. (The triac on the output is ok)
Thanks in advance for any help anyone can give.
Gaz
So four questions:
Gaz
