1/4" trs To Female xlr Input Jack
  • 1/4" trs To Female xlr Input Jack
    Is this correct?
    Balanced TRS
    Looks good to me.
    On TRS plugs, the tip is "hot" (positive), the ring is "cold" (negative), and the sleeve is ground (earthed or chassis).
    In an XLR connector, pin 2 carries the signal with normal polarity, and pin 3 carries an inverted version of the same signal. Pin 1 is ground.
    holiganbet betturkey
