LSK170F
  • LSK170F
    anybody ever use these? the datasheet only specifies A, B, and C.
    LSK170F
    And what would that be?
    Googling it only returns this lonely page where we are now.
    Post some links.
      Single N Channel JFet
      Never heard of an F
      http://www.linearsystems.com/datasheets/LSK170.pdf
        I got them as free samples directly from the company. I'll write them to see if I can get a spec sheet
          Like any other Jfet, you would need to test & match them to tighter Idss sets than 2:1. Its pretty easy to do; short the source and gate, run a 1k precision drain load and on a regulated power supply, see what the drain current is.
          F was Free Samples. They did not give away tightly matched sets unless you were Carver or a big name!
