As a tangent to this i.e. devices being troubleshot outside of their cabinets, one can also be fooled by amps pulled from their cabinet and the resulting open, unshielded, high-gain electronics hanging out for all the EMI in the world to fall upon, plus testing with a guitar from two feet away. Oscillation, hum, you name it.
In one instance, I had a Music Man amp that misbehaved only when IN the cabinet. As it turned out, the power tubes were sitting almost on top of the (retrofitted) E-V speaker magnet and caused fairly severe waveform distortion as a result of beam deflection. THIS one drove me nuts for a little while BTW.
Oh yes. They put that shielding inside the cab for a reason. Some are sneaky, Peavey uses a conductive black paint inside their cabs instead of gluing foil up. Looks like no shield, but it is shielded nonetheless.
John, that is the first time I ever heard of speaker magnet to tube interaction in real life. Up til now it has always been one of those philosophical debates in tube chats.
