Voice of Music 8810 catastrophe
  • Voice of Music 8810 catastrophe
    A short while ago I got a little VOM 8810 amp head; the tube complement is 6x4, 6v6 and 12ax7. It worked, but had too much gain for harp. So I decided to make the circuit a little bit more like a Fender Champ. I replaced the 220K and 150K plate resistors on the preamps to 100K; I replaced the 1K cathode resistor on the first half of the 12ax7 with a 1.5K ( the 2nd half already had 1.5K). I also replaced the 300 ohm cathode resistor on the 6v6 to a 470 ohm, and the 10 mfd bypass cap with a 22 mfd. When I started to enlarge the hole for the strain relief, the torque of the drill threw the amp 6 feet across the room! After cussing for about 5 minutes, I picked up the amp, checked all the solder joints, and finished installing the 3 prong cord. I put the tubes back in, plugged the amp into the variac, and brought the voltage up slowly. I got nothing; no sound, no hum, no buzz and no smoke. The tubes didn't even light up. What could have been damaged by the little mishap?
    Little mishap!
    It is amazing how much torque you can get fron a drill.
    Anyway.
    Did you test the amp, after all of those mods, but before the torque demonstration?
    If not, then you should check over your work.
    After that, treat it as a new repair.
    Remove all the tubes.
    Go across the power cord L! & L2 & check for transformer continuity when the switch is turned on.
    That will check a lot right there. The switch, the cord, the fuse, the primary connections.
    Next, go across the B+ to chassis ground.
    Always looking for shorts or low resistance.
    Check the output transformer windings.
    At this point, with the power supply drained, I would poke around looking for ground connections that must be.
    If all is well, it " the power supply should come up.
    Check all the main power points.
    B+
    The heaters.
    If all is good, start putting in tubes.
    Start with the preamp. Verify plate, cathode & heater voltages.
    Send a signal to the output tube grid.
    If everything looks good, load up the output.
    Attach the speaker or dummy load.
    Check the idle conditions of the output.
    Send it a signal.
      Thanks for your quick reply. Are L1 & L2 the black and white wires of the 3 prong chord? I scorched the treble pot/on-off switch checking voltages before my original post, so I'm thinking of Muntzing down the circuit to a 5f1 and just putting an on/off toggle there. Before immolating that pot, I got a reading of around 0.3 volts on pin 1 and pin 6 of the 12ax7, and 0 on pin 3 of the 6v6. What does that mean?
        Yes, L1 & L2 are the mains conductors. Black/ White.
        No voltage on 12AX7 pin 1 & 6 points to a failed dropping resistor.
        The plates of the output tubes run at full B+ voltage (minus the output transformer winding drop).
        The preamp tubes will have a dropping resistor (2K?) coming off of the B+.
          Did you have the chassis in a vice or clamped to your bench? It's idiotic to drill holes in metal if the piece isn't secured. You could have injured yourself.
          - Scott
          marsbahis betturkey
