Hey guys,
I have a Line 6 DM4 distortion modeler that recently started making a really bad crackling noise when used. The unit powers on fine and usually sounds okay for about 30 seconds and then begins cutting out until it eventually doesn't produce any sound at all. I'm new to pedal electronics and trying to learn more about circuitry. I also know that these circuit boards are similar to that of the DL4 delay modeler which some of the members have posted extensive repair instructions for. I was hoping that someone would be able to guide me in a direction as to what would be causing this noise. The solder joints on the input and output jack look fine and I've used reliable cables to check the issue. Any thoughts?
Thank you,
Duncan
Thank you,
Duncan
