Hey guys. I've seen 6N138s hooked up two different ways in a MIDI In circuit -
Method 1 -
Method 2 -
Is one way better/more desirable than the other?
Also in method 2, I notice that while the 1K limits the emitter base current of the first transistor, there's nothing there to limit the base current of the 2nd one. Is this acceptable due to the fact that the 2nd transistor is only sinking current during the pulse period?
I've also heard from a couple of sources that without the emitter resistor on pin 7 for the first internal transistor that the leading edge of the received byte pulse gets rounded off significantly. Anyone have any insight on this?
Method 1 -
Method 2 -
