roland tr-808 drum machine = vintage 80's
  • roland tr-808 drum machine = vintage 80's
    Hello folks,
    has anyone found a good replacement for the start/stop & Tap switches for this unit?
    They are fairly specific momentary push switches. these units are now very sought after and are selling for around $1500 at this point, so I want to make this look as original as possible.
    The switches are sealed and drilling a hole in them to get deox in was no help.
    Mouser has nothing like it that would be the same shaft size as the knob.
    thanx, glen
    Hi Glen
    No idea as to the switches, but ther service manual for the 808 is here Audio Roland : Service Manual free download,schematics,datasheets,eeprom bins,pcb,repair info for test equipment and electronics
    The manual for the 606 is also there
    Clone information for drum circuits from the TR808 is here
    eric archer . net » 808 clones if you want to build a triggerable sound module for each drum sound.
    I know its not what you are after, but maybe someone is interested.....
    Cheers
    Andy
      Smallbear Electronics carries several different momentary switches for Boss and Ibanez pedals. They might have something similar, if not identical.
        Hey thanx guys,
        I actually was able to get these little buggers apart & then coat the little carbon button with that Caigcoat stuff. It works pretty well. We've used it on keyboard sensidome strips for some of the Korgs where the strip is no longer available.
        See pix attached...thanx again all...glenClick image for larger version
ID:	820075Click image for larger version
ID:	820076Click image for larger version
ID:	820077Click image for larger version
          From the pictures you posted, the switch looks a lot like the bypass switches used in the Boss pedals. Get a few DS-1's and rob the switches out of 'em.
            Interesting
            Mars, how did you get the switch apart, and how did you get it back together? I'm facing the same problem.
              Hey guys, thanx for the suggesions. they do look like the pedal switches from the Boss variety.
              As to how I got them apart..it's a bit difficult to determine from the pix I posted, but on either corner on the bottom of the switch, there are two larger looking post 'indentations'.
              What they did was melt the top of these posts into the bottom cover of the switch. If you take a drill or possibly an exacto knife & dig-cut out the melted 'muffin top' portion of that post, the swtich will come apart.
              I orginally tried to cut the post off through the separation between the top & bottom of the switch, but quickly determined this was a problem & the switch wouldn't align correctly when I attempted to put it back together.
              the 3rd pic in my post above best shows the tiny posts. I epoxied the switch back together once I was certain the coating would hold. I did blob the coating on fairly thick, as the switch puts a fair amount of pressure on the little carbon button & I was concerned a thin layer would wear off.
              Take it slow & cautious & it's really too difficult...you only get one shot! thanx, glen
                WOW. Yes, Smallbear does have the identical switch...for only $1.95.
                Switch - SMK for BOSS DS-1
                I'll definitely go that route next time...thanx, glen
                  One Caveat...
                  I just noticed I do have some of what looks like this switch from Smallbear in stock. I tried them & as I recall, the height & size of the actuator is slightly higher & larger, so some modification will be necessary to get everything to work properly.
                  The knobs on the TR808 have a cross ' + ' shaped hole in them that has to fit the ' + ' shape of the actuator on the switch. The switch from the Boss pedals is slightly larger than the knob on the TR808, so it might be a bit tricky to get it to fit & still look ok.
                  As I recall now, I decided to go the 'repair the switch' route to keep the Tr808 as original looking as possible a well as it looked like more time involved. These things are very much in demand right now & are selling for like $1500.00!
                  I do think however that this could be accomplished...thanx again, glen
                    Sorry...I just remembered further.
                    I disassembled one of those boss switches with the idea of exchanging the rubber dome contact piece inside...they are completely different inside...the Boss switch uses hard metal contacts & not that rubber dome piece that the original has in it.
                    Just trying to save ya some time here....glen
                      Better pic of switch:
                      See attached. you can see the impressions of the top of the posts on the bottom of the switch. glen
                        Thanks!
                        I managed to do it, though it was hard to get it back together - my switch was completely sealed. I took a scalpel to the seam, cleaned the contacts, used Caig Coat as you describe, then epoxied it back together. It's now good as new, but I'd hate to have to do it again - I'm still looking for spares...
                          Service manuals,part numbers & a second type of this ALPS keyswitch
                          I tried the dismantling and epoxying approach in the past, but
                          did not succeed in making the epoxy strong enough. I used a
                          little fine wet-and-dry paper on the rubber contact, and I
                          think I used some isopropyl alcohol and then some fine wet-
                          and-dry paper on the metal contacts. In that case, I
                          installed some different kinds of switches and buttons, which
                          was far from ideal.
                          Recently, I was able to obtain two switches which were
                          proper replacements, from an unused MC-4 keypad panel.
                          These were mechanically entirely compatible, though the
                          details of the body were quite different and the shaft is
                          black, rather than white. Both types had the ALPS oval
                          trademark on the bottom. The new ones can easily be
                          unclipped and clipped back together. So if their rubber
                          contacts start to fail, it will be a matter of desoldering them
                          and unclipping the side parts to clean the contacts, rather
                          then replacing the whole switch.
                          I was wondering what the ALPS part number was, but my
                          only copy of the TR-808 service manual was an old
                          photocopy, missing the part numbers. Today, thanks to this
                          forum, I discovered Eric Archer's TR-808 clone drum sound
                          page: eric archer . net » 808 clones and was
                          very happy to find an excellent scan of the TR-808 service
                          manual there. This is "3rd printing June 1986 C-2", so I guess
                          it is the final version. (The previously mentioned service
                          manual at fileshare.eshop.bg was a .zip file in two parts and I
                          couldn't easily find a way of unzipping the two.)
                          Unfortunately there's no ALPS part number in the service
                          manual. Just listings of "KED1001" for the Start/Stop switch
                          and button combined, and "KED10903" for the Tap switch and
                          button. These have surely been out of production for 25
                          years or so, but its always good to have a part number. I
                          have some ALPS catalogues from the late 1980s and early
                          1990s, but I can't access them right now. If I find a proper
                          part number for these switches, I will post it to this forum.
                          Googling KED1001 lead to VINTAGE PLANET - Parts Service for Vintage Synthesizer Repair - Roland Parts
                          but they have none in stock. It also lead to another copy of
                          this beautifully scanned service manual:
                          http://manuals.fdiskc.com/tree/Rolan...e%20Manual.pdf
                          This directory: Index of /tree/Roland has a bunch
                          of Roland service manuals. Stepping back to the tree
                          directory, there are directories for many other musical
                          instrument manufacturers - a treasure trove of manuals,
                          including for some obscure machines.
                          There is an MC-4 manual, from 1982, which is a little after
                          the 1981 date at the top left of the TR-808 manual. So my
                          guess is the MC-4 is somewhat later and this use of the
                          black-shaft switches indicates that ALPS changed their
                          design from the heat-sealed white shaft approach to the
                          side-clip black shaft approach. Unfortunately, there's no
                          ALPS part number for the keyswitches - just KEH4AO06 for
                          the 10 key assembly, presumably with buttons included.
                          I think, with care, it may be possible to reassemble the old
                          switches and make them strong enough. I think it would
                          require epoxy on the outside of the case, with some kind of
                          reinforcing to the PCB, which would make it all hard to
                          dismantle in the future. These switches can get a lot of
                          sideways force, so I think the case needs to be well
                          supported since just epoxying the two pins is not, in my
                          experience, strong enough.
                          - Robin
                            Well that's great thanx for all the research. I do have the original manual as well am Roland authorized, so I can still print it from their authorized website. Yes, no Alps number.
                            I forgot that the switches were somewhat fused together. I was using a very sharp long exacto knife in the seam to rock it back & forth & break the seam. It wasn't fused that badly.
                            As for the epoxy...I used the 5min JB Weld (would never use the other semi-clear crap). I put a slight amount in the seam before I closed it up & I'm tellin' ya, this weld will not break.
                            the switches afforementioned that go in the boss pedals probably could be modified to work, however they only have 2 connection pins as opposed to the 4 of the original (for strong mounting given the leverage that big knob has) & as mentioned the 'Cross' shaped actuator is slightly larger than the original...wouldn't be as big an issue if the knob also had a cross mounting in it.
                            If anyone ever enounters a switch that will retrofit easier...let's post it...
                            thanx, glen
                              I just midi to a cheap keyboard and I get double 2 snares BD, CB HH, ect.Alot easyer to play live then tapping on a little keypad.Not wear it out.Istarted getting some distortion on the snare,with the Keyboard it is gone...
                              casibom< giriş/a> betturkey
