I am restoring several Klemt Echolette S tape echos that were manufactured in the mid-sixties. Here is a picture of my stable of echos:
These came to me in various states of repair from one that had been worked over by Bobby Staedel (the German Echolette guru) to one I bought from a guy in Holland that arrived with a thick layer of condensed cigarette smoke on every surface. The two shown with their guts exposed arrived in partial working condition. They both suffered from lots of distortion, even with bypassing the echo circuitry, and had very poor echos. I decided to replace as many capacitors on both of them as I could and this is no easy task. Here's a picture of a portion of the innards of one of them as I received it.
Not much room to work and you can't even see the caps that are really buried! The chassis is constructed in such a way that you can't open it up except on the two ends.
I have managed to get both of them working pretty well and the next step is to replace the two pronged cords with three prong properly grounded ones. I have done this chore previously on several amps.
Here's the question: As you can see, all of the grounds are tied together with a common bus throughout the unit. I have measured the voltage between this "chassis" ground and the actual ground on the mains supply. What sort of voltage reading might I expect?
With the two pronged cord in correctly (hot to hot and neutral to ground) I get 2 or 3 volts with the power switch off, but almost 50 v if I turn the power switch on. This seemed odd to me, so I checked the one unit with a three pronged cord. As anticipated, I read no voltage from the chassis to the ground at the wall outlet, but if I temporarily unsolder the internal ground connection I get the 50 volts. I have connected a wire from the chassis ground to the outlet ground and there is no measurable current.
I do want to install the three-pronged plugs, but I want to be certain I am not creating any new problems. Are these voltage readings "normal"?
Here's a picture of the schematic.
Sorry for the long post, but I wanted to provide as much information as possible without a long series of exchanges. Oh, BTW..the unit on the right came with a complete set of original Telefunkins. A nice surprise!
