Fender Blues Junior hissing sound on certain notes
  • Fender Blues Junior hissing sound on certain notes
    I am noticing a faint hissing sound only when I play certain notes.
    It only seem to happen when I have the preamp at 5 or above.
    I have tested my guitar and cable in another amp and it does not
    do it. So I am convinced it is the amp.
    I have pushed on the tubes and they seem to be seated fine.
    I have also lightly tapped on the tubes with my guitar unplugged
    and volume up to see if I could isolate to a tube but no good.
    Any ideas of how to troubleshoot this.
    TIA
    The amp needs a tune up?
    Can you very that fact that it is not the speaker?
    The preamp at 5 may be a hint. The pre is starting to push at that point.
    Do you have spare tubes to try?
    I would suggest changing one at a time.
      The BJ manual lists the tubes as
      6BQ5 6BQ5 12AX7 12AX7 12AX7
      I find there are several brands and price levels to choose from.
      Would there be any suggestions?
      Can you replace just 1 tube?
      Pros/cons?
        The two output tubes should be replaced in matched pairs even if one is bad. If you have had it a long time and use it often you should consider replacing all the tubes at one time. I just got a set for 62.00 dollars including shipping a few days ago.
        marsbahis betturkey
