Schematic needed for Korg DT-10 Tuner pedal.
  • Schematic needed for Korg DT-10 Tuner pedal.
    Hello,
    First let me just say Hi everyone, just starting out here.
    To the point: I'm in dire need for the DT-10 schematic, the thing just broke and I need to fix it really soon.
    Can anyone please help out?
    Thanks!
    here ya go!
      Wow that was fast. Thanks a lot!
        Does anyone have the schematic for the Korg ca-20 tuner?
          Originally posted by pk555 View Post
          Hello,
          Thanks!
          i have the same pedal,, there is one minor issue with it. I can actually hear clicks and buzzing noises through my amp that correspond with the tuner's LEDs lighting up. Is this normal?
            Hi, it’s good to see you here with us, hope you will gain much knowledge regarding electronic music system from this community. I hope PDF manual shared by Pecorporation may solve your problem, since it contains entire description with diagram which helps us in understand the concept better. Thanks Pecorporation for sharing that PDF file with us which helped me a lot.
            [url=http://www.klipsch.com/na-en/products/architectural-speaker/]in ceiling speakers[/url]
              Hello,
              I also need the schematic of Korg DT-10. I tried to get it from the tread of 'pecorporation' but I could not open the PDF. Could someone send it again?
              Michael
                Attached.
                  Thank You very much
                  Attached.
                  Thank You very much for sending me PDF of DT-10. It will realy help me to repair my tuning-unit.
                  Regards
                  Michael
