diode sub?
  • diode sub?
    Can anyone tell me which diodes i could use to create a rectifier to replace a rectifier package gone bad? The rectifier is a KBU800 rated 8A.
    They don't make many single diodes in an 8 amp rating. The ones that do exist are mostly ultrafast ones in TO220, and need bolted to a heatsink to achieve the 8 amp rating.
    So, your best bet is just to buy another rectifier.
      ok, thank you.
      casibom< giriş/a> betturkey
