Randall g2 rh250 amp head question (please help)
  • Randall g2 rh250 amp head question (please help)
    hello i have a randall g2 rh250 amp head and everytime i turn it on i get buzzing sounds out of my cab. when i unplug my cab from the back of the head its silent. when i plug it into the line out i get low volume ( even with volume all the way up with no buzzing what can i do to fix this issue? all my cables are good the cab is good thank you hope you can help
    The amp's line out is designed to be sent out to something like a tape recorder or a PA board, not to a speaker cabinet. There will never be enough signal from the line out to produce a good sound through a speaker.
    If there is no buzzing coming from the line out, then the amp's problem is probably in the main power amp section. It could be a shorted component, a broken connection on the PC board, or any number of things.
    It's time that the head be taken in for service.
    casibom< giriş/a> betturkey
