peavey xr-700 compression stays on!!
  • peavey xr-700 compression stays on!!
    so i switched out the drive board and the output transistors and the compression light stays on and is also engaged.... is there anyway to bypass this circuit or can someone point me the around the problem area
    thx in advance,
    chase
    Did the compression led come on before the repair?
    Can you post the schematic?
    marsbahis betturkey
