Anyone ever repaired a Peavey DECA 1200.
Holy moly its an ugly unit.
I have to say I'm usually a big fan of Peavey products but this amp has to be one of the worst put together units I have ever seen. all straight pin connectors, same colors most with the same pin count and no ID information.
The thing is a vibration, solder joint cracking mess as well!
Unit was working OK but would shut off from time to time. found cracked solder joints on a huge inductor bolted to one of the PCB's of the power supply, took me an hour to just take the thing apart, marking connections and making notes. two hours later back together and now one channel is stuck in DDT. Grrrrr. To Peavey for a document package now.
