wurlitzer Model 4100bw, 4102bw and 4150bw organ
  • wurlitzer Model 4100bw, 4102bw and 4150bw organ
    Hi everbody we found these drawings enjoy!Click image for larger version
ID:	863653Click image for larger version
ID:	863654Click image for larger version
ID:	863655Click image for larger version
    Well done, thanks.
      Any chance you can repost the 4100 drawings? Google lead me to a thread with no pictures!
ID:	831376Click image for larger version
        See if I did this correctly!Click image for larger version
ID:	831378Click image for larger version
ID:	831379Click image for larger version
ID:	831377Click image for larger version
          Originally posted by OMguy View Post
          [ATTACH=CONFIG]25767[/ATTACH][ATTACH=CONFIG]25768[/ATTACH]
          See if I did this correctly![ATTACH=CONFIG]25769[/ATTACH][ATTACH=CONFIG]25770[/ATTACH][ATTACH=CONFIG]25767[/ATTACH][ATTACH=CONFIG]25768[/ATTACH][ATTACH=CONFIG]25769[/ATTACH][ATTACH=CONFIG]25770[/ATTACH]
          Nope.
          To attach a file:
          Click on the following tabs
          -Reply
          -Go Advanced
          -Manage Attachments
          --New Window Opens
          --Browse (to your hard drive file/ click on your file)
          --Upload File
          --Close Window
          - Submit Reply
            Aside from all that, the files will need to be re-sized first, if they are the same files that were posted originallyl.
              I will try again ---- Thanks
              See if it goes this time!
                Nope.
                  One more time! I tried to change the file name by one. If this does not work can I e-mail them to the staff for help! Thanks------------ OMguy
                    OM guy as g-one said they have to be re-sized.. if you haven't a graphics program suitable although "paint" would probably do it (load it then save it)
                    as its jpg's you could use this
                    Resize Images online
                    and then save them and re load them here I suggest just select 75% button on that site.
                    They cannot be exactly the same size as the forum thinks it already has them.....
                    These were the original sizes so by right clicking and selecting properties you can check the size
                    or maybe by hovering over the picture file with the mouse you can see the size or in a folder with "details" selected by the view
                    menu.
                    WRLIT1.jpg - 2.21 MB
                    WRLITZ2.jpg - 961.7 KB
                    WRLITZ3.jpg - 1,001.2 KB
                    WRTLIZ4.jpg - 975.9 KB
                    They will not stick if they are still this size.
                      Wurlitzer 4100 schematic
                      OMguy sent me the files.
                      Here they are.
                        OK I will try the re-size next time. I need to read the posts more exact. Thanks to you all for the help -------- OMguy
